56 Fury differential pinion seal Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
Tony |
Elite Veteran Posts: 640 Location: Falcon, CO | Hi All, <br/> What is the diameter of the ring gear for 1956? O'Reilly Auto and Rockauto claim that the Fury came with a 303 had a 8 3/4" ring gear. I need to replace the pinion seal, and both say that National 7216 is the correct seal. I still have to pull the yoke and the old seal, it'll be a couple days before I get to it. <br/> Any info will help, <br/> <br/> Thanks, <br/> Tony | ||
Expert 5K+ Posts: 9909 Location: Lower Mainland BC | <div class="quotation">Tony - 2019-06-17 5:18 PM <br/>
<br/>
Hi All, <br/>
What is the diameter of the ring gear for 1956? O'Reilly Auto and Rockauto claim that the Fury came with a 303 had a 8 3/4" ring gear. I need to replace the pinion seal, and both say that National 7216 is the correct seal. <br/>
</div> <br/>
<br/>
And then again O'Reilly and Rockauto could full of Sh1t? Pretty sure those older <b></b>(to 1957<b></b>) diffs were 8 1/4" at least for everything smaller than an Imperial, e.g. Dodges and Plymouths. And then there was this: <br/>
<br/>
<div class="quotation">ybshore - 2018-09-06 4:22 AM <br/>
<br/>
Older <b></b>(pre '57<b></b>) 8-3/4 diffs will not fit into the true 8-3/4 <b></b>('57 and later<b></b>) axle housing. The axle housing has a different bolt pattern for the carrier, the axles have different splines, and the axle bearings are all different. I've been looking for the pinion seal for my '56 Imperial and can't find a source. It's 2 5/8 ID x 3 1/2 OD. Can anyone send me to a lead? TY. <br/>
</div> <br/>
<br/>
I think the rear diff seal that you are looking for for your 56 Plymouth <b></b>(yes, I know it's a Fury - but it's not an Imperial<b></b>) is a 3.11 inch diameter 663 602 <b></b>(as shown below<b></b>) <br/>
<br/>
<img src="http://www.forwardlook.net/forums/forums/get-attachment.asp?action=view&attachmentid=192354"> <br/>
<br/>
Like this one: <br/>
<br/>
<a href="https://www.ebay.com/p/Rear-Axle-Pinion-Seal-1937-1957-Dodge-Plymouth-Cars-663602/844721015" target="_blank" title="https://www.ebay.com/p/Rear-Axle-Pinion-Seal-1937-1957-Dodge-Plymouth-Cars-663602/844721015">https://www.ebay.com/p/Rear-Axle-Pinion-Seal-1937-1957-Dodge-Plymout...</a> <br/>
<br/>
Or this modern one from SKF, i.e. 18880: <br/>
<br/>
<a href="https://www.rockauto.com/en/parts/skf,18880,differential+pinion+seal,2380" target="_blank" title="https://www.rockauto.com/en/parts/skf,18880,differential+pinion+seal,2380">https://www.rockauto.com/en/parts/skf,18880,differential+pinion+seal...</a> <br/>
<br/>
<a href="https://www.rockauto.com/en/moreinfo.php?pk=1837032&jsn=3" target="_blank" title="https://www.rockauto.com/en/moreinfo.php?pk=1837032&jsn=3">https://www.rockauto.com/en/moreinfo.php?pk=1837032&jsn=3</a> <br/>
<br/>
<img align='middle' src='http://www.forwardlook.net/forums/images/emoticons/smile.gif'> <br/>
<br/>
Edited by 56D500boy 2019-06-18 1:46 AM | ||
Tony |
Elite Veteran Posts: 640 Location: Falcon, CO | Thanks for the info Dave, I know the '56 diff looks like an 8 3/4, but could tell the case is smaller. | ||
Expert 5K+ Posts: 9909 Location: Lower Mainland BC | <div class="quotation">Tony - 2019-06-18 6:17 AM <br/> <br/> Thanks for the info Dave, I know the '56 diff looks like an 8 3/4, but could tell the case is smaller. <br/> </div> <br/> <br/> The issue of diff size is moot. You don't have an 8 3/4". <br/> <br/> I have a NAPA/SKF 18880 in my hand. The spec are as in the link, i.e. <br/> <br/> Width <b></b>(in<b></b>) 0.5 <br/> Shaft <b></b>(in<b></b>) 1.875 <br/> Bore <b></b>(in<b></b>) 3.105 <br/> Outer Diameter <b></b>(in<b></b>) 3.11 <br/> <br/> Should be the modern <b></b>(no felt<b></b>) equivalent of the OE 663 602. <br/> <br/> <img align='middle' src='http://www.forwardlook.net/forums/images/emoticons/smile.gif'> | ||
Tony |
Elite Veteran Posts: 640 Location: Falcon, CO | Thanks again Dave, I have lots of local sources, including a company specializes only in seals & bearings. | ||
Expert 5K+ Posts: 9909 Location: Lower Mainland BC | <div class="quotation">56D500boy - 2019-06-18 7:31 AM <br/>
<br/>
I have a NAPA/SKF 18880 in my hand. <br/>
</div> <br/>
<br/>
In case you thought I was BS'ing about "in my hand": <br/>
<br/>
(NAPASKF18880RearDiffPinionSealJune18_2019.jpg) Attachments ---------------- NAPASKF18880RearDiffPinionSealJune18_2019.jpg (115KB - 208 downloads) | ||
mobileparts |
Veteran Posts: 253 | Did you get the correct one???? Do you still need it????? <br/> I have EVERY MOPAR pinion seal ever used, including the impossible to find CROWN IMPERIAL !!!!!!! <br/> <br/> Always best to simply call me --- Craig -- 516- 485 - 1935...... | ||
Tony |
Elite Veteran Posts: 640 Location: Falcon, CO | I believed you, the closest NAPA didn't have it, but I picked it up at the NAPA warehouse in Colorado Springs this afternoon. I'll be working on my friend's Fury Thursday. <br/> Thanks again guys, | ||
Tony |
Elite Veteran Posts: 640 Location: Falcon, CO | I just compared the measurements for National 7216 and SKF 18880, the measurements are identical except that the 7216 still uses leather instead of rubber. | ||
Tony |
Elite Veteran Posts: 640 Location: Falcon, CO | Installed the new SKF seal this afternoon. (100_9421rs.jpg) Attachments ---------------- 100_9421rs.jpg (109KB - 250 downloads) | ||
Expert 5K+ Posts: 9909 Location: Lower Mainland BC | <div class="quotation">Tony - 2019-06-20 4:48 PM <br/>
<br/>
Installed the new SKF seal this afternoon. <br/>
</div> <br/>
<br/>
Looks good. <img align='middle' src='http://www.forwardlook.net/forums/images/emoticons/smile.gif'> <br/>
<br/>
Any chance that you counted the splines on the pinion shaft/pinion flange? <br/>
<br/>
I am getting mine changed on Tuesday <b></b>(I'm also going to a 58 style pinion flange and a 7260 type U-joint at the same time<b></b>). <br/>
<br/>
<img align='middle' src='http://www.forwardlook.net/forums/images/emoticons/smile.gif'> Edited by 56D500boy 2019-06-21 1:31 AM | ||
Tony |
Elite Veteran Posts: 640 Location: Falcon, CO | I didn't, but I estimate 8-9, I can see 5 in the pic. Should it be 10? | ||
Expert Posts: 3778 Location: NorCal | All early 8 1/4" pinions are 10-spline. | ||
Expert 5K+ Posts: 9909 Location: Lower Mainland BC | <div class="quotation">Tony - 2019-06-20 4:48 PM <br/> Installed the new SKF seal this afternoon. <br/> </div> <br/> <br/> I had an 18880 installed in my 56 Dodge rear diff on Tuesday and I think that it is leaking. I am sure that the shop will say that because I provided the new pinion flange <b></b>(yoke<b></b>) *AND* the SKF seal, it's their fault. <img align='middle' src='http://www.forwardlook.net/forums/images/emoticons/frown.gif'> <br/> <br/> How did you remove the pinion flange nut? I thought that I couldn't do it with the car on the garage floor <b></b>(even jacked up with jack stands<b></b>). Now I will probably have to redo the seal. <img align='middle' src='http://www.forwardlook.net/forums/images/emoticons/frown.gif'> :<b></b>( <br/> <br/> <img align='middle' src='http://www.forwardlook.net/forums/images/emoticons/smile.gif'> | ||
