57 De Soto 392
macedon
Posted 2019-07-10 4:22 PM (#584663)
Subject: 57 De Soto 392
5001001001001002525
OK, for the purists just look away... nothing to see here.
I did look around a bit, did some searches and not a whole lot came up. So I am considering going with a 392 in my 57 De Soto 4dr hdtp. The motor is out of the De Soto... I even have the front clip off. The 392 came out of a 57 Imperial. Anybody here ever done this? Or know of a write up on it. I just want to know what I'm up against if I do decide to swap out the 341 for a 392. I also have the tranny that came with the Imp 392. I also have the drive shaft and rear end from a 58 New Yorker.
Posted 2019-07-10 6:28 PM (#584667 - in reply to #584663)
Subject: RE: 57 De Soto 392
5000200020005001002525
The 392 should be able to mount to the same motor mounts and transmission, converter & plate as your DeSoto. Just pull the DeSoto motor and install the 392 in it's place. I recommend using the truck 4-bolt exhaust as the original '57 exhaust is the limiting factor that reduces it's output potential. And use a 30 degree angled oil filter. There really are no issues with making this swap, it's a bolt-in deal.
But the 4-bolt exhaust get's pretty tight in there so you may need to adjust those motor mounts a bit to make it fit well. But I found that a centered mount worked best on my car.
Edited by Powerflite 2019-07-10 6:32 PM
Posted 2019-07-10 6:35 PM (#584668 - in reply to #584663)
Subject: Re: 57 De Soto 392
5000
why swap a 341 hemi for a 392?
macedon
Posted 2019-07-10 6:41 PM (#584670 - in reply to #584663)
5001001001001002525
Sweet. That's very encouraging. Thanks
macedon
Posted 2019-07-10 7:22 PM (#584674 - in reply to #584668)
5001001001001002525
mikes2nd - 2019-07-10 5:35 PM
The 341 was taken apart for rebuild and the machine shop never finished and lost some parts. So I have an incomplete 341 and a running 392.
ToMopar
Posted 2019-07-15 1:38 PM (#584858 - in reply to #584674)
10001002525
macedon - 2019-07-11 12:22 AM
Dave, you are a lucky guy to have those motors.
Powerflite - 2019-07-10 11:28 PM
Nathan, what kind of 30 degree oil filter is it. Only available for the 392 or other motors, too
Edited by ToMopar 2019-07-15 1:39 PM
Posted 2019-07-15 2:46 PM (#584862 - in reply to #584663)
It is sold by Hot Heads. They work with all the early hemi and hemi based poly motors, including DeSoto. They sell vertical down, forward, and 30 degree up versions.
http://hothemiheads.com/oiling_system/oil_filter_adapter_30d.html
Edited by Powerflite 2019-07-15 2:48 PM
wayfarer
Posted 2019-07-17 3:41 PM (#584932 - in reply to #584663)
500100100100252525
Actually, that 30° mount does not fit on a 330-341 DeSoto without doing some whittling on an 'ear' on the block.....Recently tried to use one on a customer's engine.
I did not verify the fit prior to assembly of the block ('they' said it would fit...) and chose to not do any grinding on the assembled unit.
I'll offer photos of the area to anyone contemplating use on a 330-341. I have not checked the 276-291.
Posted 2019-07-17 3:49 PM (#584934 - in reply to #584663)
The aluminum mount interfered with the block or the oil filter itself?
wayfarer
Posted 2019-07-18 3:50 PM (#584971 - in reply to #584663)
500100100100252525
mount vs block
Photo is too large to post here and IDK how to resize it w/o use of a Photobucket type service which I
no longer use.
Edited by wayfarer 2019-07-18 3:55 PM
macedon
Posted 2019-07-18 5:06 PM (#584975 - in reply to #584971)
5001001001001002525
If you have windows it comes with snipping tool. Works fine
wayfarer
Posted 2019-07-19 1:48 PM (#584995 - in reply to #584663)
500100100100252525
...? I'm 70 now, use windows 7, no clue what a snipping tool is.....and my 'flip' phone works just fine....
Posted 2019-07-19 2:48 PM (#584996 - in reply to #584971)
500020002000500100100100100
wayfarer - 2019-07-18 12:50 PM
no longer use.
As suggested in my Photo Posting hints thread, IRFANVIEW is what I use to resize my photos and/or convert .jpegs to jpgs. Easy to use and it's free.
https://www.irfanview.com/
REFERENCE: http://www.forwardlook.net/forums/forums/thread-view.asp?tid=64340&...
Posted 2019-07-20 12:46 PM (#585026 - in reply to #584995)
20001000500100100252525
wayfarer - 2019-07-19 10:48 AM
I'm 75 and use Windows 7...try this:
https://www.bricelam.net/ImageResizer/
Once installed simply right-click the image to resize it.
Posted 2019-07-20 1:30 PM (#585029 - in reply to #584663)
5000
https://www.getpaint.net/download.html#download
install, open picture, click on "image" then Resize... select typically 50%... save as... and change to jpg.... select level and make sure its under 250... save and upload
wayfarer
Posted 2019-07-20 7:08 PM (#585034 - in reply to #584663)
500100100100252525
Lets see what happens... OK, I have learned something new today. Many Thanks to 57Chizler
Edited by wayfarer 2019-07-20 7:21 PM
(330 oil filter mount 001 (Small).JPG)
Attachments 330 oil filter mount 001 (Small).JPG (103KB - 196 downloads)
Posted 2019-07-21 12:07 AM (#585039 - in reply to #584663)
5000
actually this one will let you simply "right click" on the picture and resize it. That's pretty awesome and its free.
https://github.com/bricelam/ImageResizer/releases/
Posted 2019-07-21 12:11 AM (#585040 - in reply to #584663)
5000
that app is amazing... btw... the only way to go... I think I am going to program an option to "set max size" and use the jpeg encoding to lower it as needed to meet the "size requirement". You can set the jpg encoding factor to whatever you want but you still cant be sure about the final size.
