iron case torqueflite
oliver
Posted 2019-07-17 5:26 PM (#584941)
Subject: iron case torqueflite
New User
hello, i have a 58 dodge mayfair. the trans is a pushbutton 3spd. i have been trying to rebuild it. its all together but when reverse is engaged it will back up but drive forward when engine rpm is above 1000. it was a complete overhaul that included a new shift cable. anyone ever seen or heard of this?
Posted 2019-07-18 1:49 AM (#584956 - in reply to #584941)
Subject: Re: iron case torqueflite
50005000200010002525
Internal leakages - most probably seal ring/s broken due to wear in the bore
oliver
Posted 2019-07-18 7:59 AM (#584959 - in reply to #584941)
New User
Thanks, I'll pull it back out and see what I find. Oliver
oliver
Posted 2019-07-30 3:25 PM (#585393 - in reply to #584941)
New User
thanks! the sealing rings that i had installed were not correct. i could not find any n.o.s. and gave up on aftermarket since the two sets i had purchased were not exactly the same. i just reused the originals and the trans shifts great.
