rubber brake hose from master to distribution block
brand209
Posted 2019-10-09 6:31 PM (#588629)
Subject: rubber brake hose from master to distribution block
I need to find this hose does anyone have a part number 56 plymouth, goes from the bottom of the master cylinder to the distribution block
Posted 2019-10-09 9:36 PM (#588639 - in reply to #588629)
Subject: RE: rubber brake hose from master to distribution block
50005000500100
brand209 - 2019-10-09 3:31 PM
In theory, there are two PNs, depending on which transmission your car has. That said, I am running a 1554 357 (Raybestos H-21176) on my Powerflite equipped 56 Dodge and now I find out that it is supposed to be for a standard transmission car (why, I don't know). I am supposed to be running a 1614 799 but based on the Dorman numbers, I have the feeling that both numbers are really the same hose.
Lots of options out there:
https://www.google.com/search?client=firefox-b-d&q=Raybestos+H-21176
https://www.rockauto.com/en/moreinfo.php?pk=968827&cc=1331581&jsn=10...
"Alternate/OEM Part Number(s): 1614799, 88216, 9750941, BH21176"
Edited by 56D500boy 2019-10-09 9:54 PM
(55-58BrakeSystemDiagram.jpg)
(55-58MasterCylinderToTeeBrakeHosePNs.jpg)
Attachments 55-58BrakeSystemDiagram.jpg (185KB - 272 downloads)
Attachments 55-58MasterCylinderToTeeBrakeHosePNs.jpg (190KB - 274 downloads)
brand209
Posted 2019-10-10 1:05 PM (#588658 - in reply to #588629)
Subject: Re: rubber brake hose from master to distribution block
Thank you for the help, the dorman one you posted has a fluted coupler type nipple on the end where as mine is flat though it does look like my hose. The car is a 2 speed automatic
Posted 2019-10-10 1:49 PM (#588661 - in reply to #588658)
50005000500100
brand209 - 2019-10-10 10:05 AM
This?
https://www.dormanproducts.com/p-14526-h21176.aspx
brand209
Posted 2019-10-11 1:25 PM (#588691 - in reply to #588629)
yessir though I could be wrong since there is another part that screws into the bottom of the mc that this might connect into
Posted 2019-10-11 3:40 PM (#588698 - in reply to #588691)
50005000500100
brand209 - 2019-10-11 10:25 AM
Yes. Mine has a brass bushing/adapter that was screwed into the bottom of the MC and is set-up to work with the flare on the metal part of the rubber hose. I am pretty sure that the brass adapter came with the new Raybestos MC but even if it didn't they are easy to find.
(56DodgeSingleMasterCylinderToRubberHoseBrassAdapter.jpg)
Attachments 56DodgeSingleMasterCylinderToRubberHoseBrassAdapter.jpg (101KB - 245 downloads)
brand209
Posted 2019-10-16 7:08 PM (#588919 - in reply to #588629)
you are correct, I ordered a new hose it is on the way and I will make sure to add a new connector to it
