Power steering pump differences 1957-1961
brdtee
Posted 2019-11-24 3:58 AM (#590642)
Subject: Power steering pump differences 1957-1961
100100
For my 1957 Windsor with 354 I have a power steering pump with single pulley and it's the "TRW" style pump just like the original. The seller told me it was from a 1961 Chrysler but wasn't 100% sure. The pump seems to fit bracketwise and also pulley lines up even the 1957 had double pulleys.
Now I'm trying to buy a power steering pump seal kit for the pump but what I see from Rockauto and other vendors, there are OEM different parts codes for every year and some years have even two options for a OEM code with different numbers also on the seal kits they offer.
I wonder how I could identify the pump I have to get just the correct seal kit for it?
Posted 2019-11-24 6:56 AM (#590644 - in reply to #590642)
Subject: Re: Power steering pump differences 1957-1961
5000100010010010010025
All I know is -60 vs 61+ is different, the pump not the steering box. The 61+ has a larger shaft for some reason. I believe the 57 PS-system (pump/box) is completely different than the 58+ system.
ToMopar
Posted 2019-11-24 9:32 AM (#590650 - in reply to #590642)
50010010010025
Heikki, check this thread; http://www.forwardlook.net/forums/forums/thread-view.asp?tid=70903
maybe it helps
brdtee
Posted 2019-11-24 11:26 AM (#590664 - in reply to #590642)
Subject: RE: Power steering pump differences 1957-1961
100100
So far I have found out the model "1738652" pump which was used 1961-1966. Not yet sure which seal kit would be correct.
