Nick's Garage tries a 54 Dodge 241 4bbl hemi (Indy Pace Car clone) on their dyno Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
Expert 5K+ Posts: 9904 Location: Lower Mainland BC | . Lots of screwing around but worth watching if you are a 241, 270, 315 or 325 Dodge hemi owner (in my opinion). I learned a few things for sure. This: https://www.youtube.com/watch?v=kafSJu-eYFE Edited by 56D500boy 2020-02-15 11:34 PM | ||
Brushwolf |
Veteran Posts: 292 Location: Twin Cities MN | Yep, good info.. Regarding the bellhousing.. I have an engine test stand and figured to use a truck stick hemi bell and flywheel for starter provisions. What I wonder though is whether the aluminum plate for auto transmissions was used on the sticks too? I got a 315 truck hemi and parts along with the 325 factory hemi and it was a basically a load of parts, so I didn't remove the truck bell myself, so idk.. Or does a truck bell bolt direct to motor on the big iron truck bellhousing? Guess I will find out when the snow melts.. | ||
58coupe |
Expert Posts: 1740 Location: Alaska | The standard trans. bellhousings bolt directly to the block without the aluminum spacer plate. | ||
Expert 5K+ Posts: 9670 Location: So. Cal | I agree. My truck with 4-speed has no adapter either. | ||
Expert 5K+ Posts: 9670 Location: So. Cal | I was mildly impressed with it until he said he built it to stock specs. He even admitted that the compression was only around 7.5:1. Why would you keep such a crappy compression??? Bump it up to around 10.5:1 with a decent cam & shorty headers, and you would see what it could really do. The poor motor can barely keep running with that crappy compression level. I really don't understand why people want to build a motor with the same crap specs that it came with from the factory. Sure, custom pistons cost money, but an extra $400 is well worth it to get a motor that can really perform like a hemi should. If you're not willing to do that, why rebuild it at all?? I didn't listen to the whole thing, so maybe he didn't build the bottom of the motor and left it as it was. That would be the only good excuse for that. Edited by Powerflite 2020-02-26 1:23 PM | ||
Mopar1 |
Expert Posts: 3034 Location: N.W. Fla. | Powerflite - 2020-02-26 12:20 PM Advertised C/R was 7 or 7.1:1. On Doc Fromader's old Webrodder site they built a 241. The OEM C/R measured out at 6.19.I was mildly impressed with it until he said he built it to stock specs. He even admitted that the compression was only around 7.5:1. Edited by Mopar1 2020-03-01 5:29 PM | ||
wayfarer |
Elite Veteran Posts: 888 Location: Peoples Republic of Oregon | Yeah, gotta agree with Powerflite, why bother to do all of the work for only half of the potential benefits? We haven't sent an engine out of the shop without 10:1 forgings in over 20 years. | ||
Expert 5K+ Posts: 9670 Location: So. Cal | Mopar1 - 2020-03-01 2:28 PM Advertised C/R was 7 or 7.1:1. On Doc Fromader's old Webrodder site they built a 241. The OEM C/R measured out at 6.19. Wow, that really sucks. That's my experience too, that the actual compression is typically lower than what's advertised. That makes this combo extremely lame. Built right, that motor should easily put out 250 hp or more. | ||
