300c vinJump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
| Forward Look Technical Discussions -> Fender/VIN Tag and Broadcast Sheet Decoding | Message format |
| STOCKHEMI |
Veteran Posts: 152 ![]() ![]() ![]() | hi fellow members i would like if someone has information on a 300c options on vin 3N571279 need to check on a car is not a clone ,help is very appreicated | ||
| springsweptwing |
Elite Veteran Posts: 1159 ![]() ![]() ![]() ![]() Location: Blackpool, United Kingdom. | Hi Graeme, VIN just tells you it's a 1957 300C, need the data plate on right hand side of radiator support. | ||
| 56D500boy |
Exner Expert 10K+ Posts: 11041 ![]() ![]() ![]() ![]() Location: Lower Mainland BC | . Just the VIN tells you very little. You need to post a photo of the data tag get more info. That said 3N571279 *seems* to be a real 1957 Chrysler 300 C VIN. They started with 3N571001 (see below) You should probably contact the Chrysler 300 club unless you are concerned that someone there might scoop it out from underneath you (??) 55-57 Chrysler VIN numbers: Edited by 56D500boy 2020-02-19 3:44 PM (55-57ChryslerVINnumbers.jpg) Attachments ---------------- 55-57ChryslerVINnumbers.jpg (139KB - 531 downloads) | ||
| STOCKHEMI |
Veteran Posts: 152 ![]() ![]() ![]() | hi paul im afraid what makes me suspicious is theres no data plate ? beleave its a cloud white car but gas no options at all | ||
| springsweptwing |
Elite Veteran Posts: 1159 ![]() ![]() ![]() ![]() Location: Blackpool, United Kingdom. | Seller would be best contacting chrysler historical and getting a copy of build sheet, it's free to do, or contact the 300 club see if it's known to them, searched vin on Google and nothing comes back on it. | ||
| STOCKHEMI |
Veteran Posts: 152 ![]() ![]() ![]() | paul yes thanks this is what i was thinking ,i have contacted rob kern at the 300 club to bring more light on the vin spec and car , it only has power steering and brakes ? though it has quarter panel medallion trim and holes ? where the vin plate is located the steel plate behind it has been replaced and fixed with self tapers and weld .and the hole car is in primer has some 300 seat interior | ||
| finsruskw |
Expert Posts: 2389 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Location: Eastern Iowa | Car is known to the 300 club and was /is originally Cloud White Last know owner of record was a Mr. Slattengren circa 2018 from CA Edited by finsruskw 2020-02-19 6:54 PM | ||
| STOCKHEMI |
Veteran Posts: 152 ![]() ![]() ![]() | many thanks for the information would you know any options to the car as present there is no power seat/windows/air con ,or possible contact to the last owner | ||
| frwl |
Expert Posts: 2306 ![]() ![]() ![]() ![]() | . This 3N57*1279 car was built on the third decade of January 1957… The 3N57*1263 car has SCHED 0123 = January 23, 1957 The 3N57*1342 car has SCHED 0128 = January 28, 1957 Your car would be scheduled between them… Between January 23 and January 28, 1957… | ||
| STOCKHEMI |
Veteran Posts: 152 ![]() ![]() ![]() | Many thanks for help with this car to everyone much appreicaited i have one final question would anyone have contact details of MR slattengren CA zip thanks | ||
| finsruskw |
Expert Posts: 2389 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Location: Eastern Iowa | have you bought tis car? Or are you looking to buy it? Someone else owns it now I assume. | ||
| STOCKHEMI |
Veteran Posts: 152 ![]() ![]() ![]() | i am decending on buying the car for parts at present from the exiting owner | ||
| springsweptwing |
Elite Veteran Posts: 1159 ![]() ![]() ![]() ![]() Location: Blackpool, United Kingdom. | STOCKHEMI - 2020-02-21 3:26 PM i am decending on buying the car for parts at present from the exiting owner (FB_IMG_1586704251964.jpg) Attachments ---------------- FB_IMG_1586704251964.jpg (72KB - 513 downloads) | ||
| finsruskw |
Expert Posts: 2389 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Location: Eastern Iowa | Very possible a low optioned car. I once had a D that was crank windows and power seat. Join the 300 Club. They can tell you what the car had for options when it left the factory. Is the car in the UK at present? | ||
| Powerflite |
Exner Expert 10K+ Posts: 10485 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Location: So. Cal | I hope you're not really going to part it out. I have motor number 1313 in my 300C, which isn't the original. I would be willing to trade out the motor to the car that this motor actually belongs to. | ||
| StillOutThere |
![]() ![]() ![]() ![]() ![]() Location: Under the X in Texas | Once owned by Mr. Slattengren. Originally a white car. Original engine number was 1304. I don't have information on the car's options. You have to remember that in '57 pretty much everything was NOT included even on a 300C. If you got Power Steering it had to be checked on the option list. Windows optional. Seats optional. Tinted glass did not even come standard if you ordered AC -- you had to order the glass option seperately. | ||
| STOCKHEMI |
Veteran Posts: 152 ![]() ![]() ![]() | Paul hi sorry for not getting back ,didnt see this picture earlier ,where did you get it from , hows the desoto going cheers | ||
| STOCKHEMI |
Veteran Posts: 152 ![]() ![]() ![]() | Nathan Hi sorry for the late response what is your 300 c vin ,against your engine vin this engine number is 1304 against 1279 vin thanks graeme still documenting the car at present ,wanting to see chassis number if possible over left chassis rail ? | ||
| Powerflite |
Exner Expert 10K+ Posts: 10485 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Location: So. Cal | My VIN number is 2761, but I'm not sure which motor number was correct for it yet. I don't know why the motors swapped around so much, I guess because they were parted out at some point in their life and the motors lived on in a drag car or something. All of my '57 Chryslers have had the motor number stamped on the right side of the frame, just in front of the spring hangar. So check there first. | ||
| STOCKHEMI |
Veteran Posts: 152 ![]() ![]() ![]() | It would be intresting to know what number difference was between vin and engine number at the time of production maybe someone out there knows. In the day they were such sort after engines for the drag boys until the RB blocks were cast. by chance have you any interior trim avalible ? cheers graeme | ||
300c vin
