Is this torque converter for a 318 or 360?
jboymechanic
Posted 2020-03-01 10:36 PM (#595058)
Subject: Is this torque converter for a 318 or 360?
2000100252525
I need to know if this is a 318 (internally balanced) or 360 (externally balanced) torque converter.  This TC came with my A518 overdriver automatic (in an early to mid 1990s Dodge van with a Magnum engine), but I don't know what exact engine it was mated to originally.  Do the weights mean its externally balanced?  Or is there a marking on the TC (or trans) that will tell me?  I need the appropriate lock-up TC for my 318.
Edited by jboymechanic 2020-03-01 10:46 PM
(thumb_IMG_0705_1024.jpg)
(thumb_IMG_0706_1024.jpg)
(thumb_IMG_0707_1024.jpg)
(thumb_IMG_0708_1024.jpg)
(thumb_IMG_0709_1024.jpg)
(thumb_IMG_0710_1024.jpg)
Attachments thumb_IMG_0705_1024.jpg (175KB - 295 downloads)
Attachments thumb_IMG_0706_1024.jpg (194KB - 265 downloads)
Attachments thumb_IMG_0707_1024.jpg (191KB - 255 downloads)
Attachments thumb_IMG_0708_1024.jpg (174KB - 265 downloads)
Attachments thumb_IMG_0709_1024.jpg (165KB - 265 downloads)
Attachments thumb_IMG_0710_1024.jpg (148KB - 255 downloads)
60SportSuburban
Posted 2020-03-02 12:21 AM (#595059 - in reply to #595058)
Subject: Re: Is this torque converter for a 318 or 360?
The weight is for an externally balanced engine (360)
jboymechanic
Posted 2020-03-02 9:57 AM (#595070 - in reply to #595058)
2000100252525
I think I found the answer, it appears the torque converters were universal for the Magnum engine series while the flex plate carried the weights for external balance for the 5.9 Magnum.
http://www.magnumswap.com/automatic-transmission-details/
Posted 2020-03-02 3:56 PM (#595086 - in reply to #595070)
20001000500100100252525
That site claims "The 5.9 Magnum uses a weighted flexplate and a neutral-balanced converter from the factory."
This is true of only the '96-later Magnum, the '93-'95 Magnum has the weight on the converter. The number 642 is a common rebuilder's number for the '93-'95 5.9 Magnum converter, it has a 91 gram square weight.
jboymechanic
Posted 2020-03-02 11:33 PM (#595115 - in reply to #595058)
2000100252525
Ok, thank you for the info. Can you help me narrow down what this trans was from/when it was built? Number above pan is PK52118328 2158 5330
Posted 2020-03-03 4:25 PM (#595145 - in reply to #595115)
Forgot to mention, the 642 converter is a lockup. PK52118328 is a 518 (46RH) OD transmission from a '93-'95 Dodge PU, build date 2158 is around October/November '94.
jboymechanic
Posted 2020-03-04 12:24 PM (#595205 - in reply to #595058)
2000100252525
Thank you for confirming, but where/how are you getting this information 57chizler?
Posted 2020-03-04 1:45 PM (#595211 - in reply to #595205)
Converter info from converter rebuilder's catalog.
Trans info from the The Hollander Interchange
Build date from a 10,000 day calendar that began on December 14, 1988
