59 Dodge D500 4 door hardtop - $22.5K Moderators: ronbo97 Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
Forward Look Swap Meet -> For Sale - EBAY, CRAIGSLIST & OTHER FINDS | Message format |
jbloving |
Member Posts: 17 | Seller claims it's a numbers matching car, but with aftermarket wheels. https://greensboro.craigslist.org/cto/d/greensboro-dodge-custom-d500... | ||
Suddenlyits1960! |
Extreme Veteran Posts: 403 Location: California | Beautiful looking car. It has the speed minder option and power seats! | ||
Suddenlyits1960! |
Extreme Veteran Posts: 403 Location: California | Out of the 1959 cars I like the dodges the best. | ||
CaprockClassics |
Elite Veteran Posts: 628 Location: Lubbock, TX | California-Spec air cleaner in the trunk. Might imply the car was shipped there originally. Nice car from what I can see! ~Peter | ||
ronbo97 |
Expert Posts: 4042 Location: Connecticut | Yes, it's a California car. You can tell by the data plate with the tape strip across it. Interior appears to have been redone. Engine rebuilt and inexplicably painted blue. Ron | ||
frwl |
Expert Posts: 1890 | . So, M2 =3 means a D500 option... | ||
frwl |
Expert Posts: 1890 | ,. M2 = 3 is a D500 (01313_ko5axQFxhYj_0ww0ii_1200x900.jpg) Attachments ---------------- 01313_ko5axQFxhYj_0ww0ii_1200x900.jpg (88KB - 163 downloads) | ||
frwl |
Expert Posts: 1890 | . What about M3 = 8 and M4 = 9? Anybody knows? | ||
dodge59 |
Elite Veteran Posts: 1018 Location: Milwaukee Wisconsin | why is it that the pink cowl tag appears to be from 1958 year . 1959 cowl tags should look like this . This is a real 59 tag d500 car . (Bob Bond's 59 Dodge Conv Data Plate copy 50%.JPG) Attachments ---------------- Bob Bond's 59 Dodge Conv Data Plate copy 50%.JPG (54KB - 165 downloads) | ||
Expert 5K+ Posts: 9904 Location: Lower Mainland BC | dodge59 - 2020-09-21 9:11 AM why is it that the pink cowl tag appears to be from 1958 year . 1959 cowl tags should look like this . This is a real 59 tag d500 car. You probably missed it: the "Pink" cowl data tag is from an Los Angeles-built car whereas your red tag is from a Detroit built car. Detroit and LA tags are pretty very different. Ain't this fun?? LA (it says right on the tag): Detroit: Edited by 56D500boy 2020-09-21 7:41 PM | ||
dodge59 |
Elite Veteran Posts: 1018 Location: Milwaukee Wisconsin | <p>Ok ..... didn't know that about the different build location data tags . Thanks !</p> Edited by dodge59 2020-09-21 4:29 PM | ||
dodge59 |
Elite Veteran Posts: 1018 Location: Milwaukee Wisconsin | Yep........ it is a real d500 , found more info on fwlk to confirm . what about the other 2 codes 8 and 9 ? anyone ? | ||
frwl |
Expert Posts: 1890 | . I can guess: M3 = 8 = 318 = Fin End Chrome Inserts, Dual Rear Antennas, Rear License Plate Frame (Ornamental Accessory Group #318) M3 = 9 = 419 = Fin End Chrome Inserts only M4 = 9 = 429 = Roof Molding | ||
frwl |
Expert Posts: 1890 | . In addition: 419= Sweep Moulding would be (9 is that and 8 is a 318 Acc Group No. 8) 429 = Roof Moulding (1.jpg) (2.jpg) Attachments ---------------- 1.jpg (89KB - 162 downloads) 2.jpg (172KB - 168 downloads) | ||
dodge59 |
Elite Veteran Posts: 1018 Location: Milwaukee Wisconsin | another thing I noticed is it has the FLAT dual antenna bases used in 1958 instead of the raised. maybe a early production of the car ..... just used up old stock from 1958 or a california made thing. | ||
frwl |
Expert Posts: 1890 | . SO 1126 on the cowl tag means November 26, 1959 it is a early car production probably | ||
frwl |
Expert Posts: 1890 | . November 1958, not a 1959 | ||
Expert 5K+ Posts: 9904 Location: Lower Mainland BC | frwl - 2020-09-22 10:13 AM. November 1958, not a 1959 I think what you meant was 1126 = November 26, 1958 = 1959 Model Year car With this face, how can it not be a 1959? | ||
dodge59 |
Elite Veteran Posts: 1018 Location: Milwaukee Wisconsin | Soooooo.....11-26 might explain why it has the flat antenna bases from 1958. | ||
58coupe |
Expert Posts: 1740 Location: Alaska | Notice the heater hoses are not connected, maybe it needs a new heater core or valve. | ||
ronbo97 |
Expert Posts: 4042 Location: Connecticut | dodge59 - 2020-09-22 6:30 PM Soooooo.....11-26 might explain why it has the flat antenna bases from 1958. No. It has tapered bases, as it should. Ply and Dodge went with the tapered bases after the 57 model year. Ron | ||
dodge59 |
Elite Veteran Posts: 1018 Location: Milwaukee Wisconsin | ronbo97 - 2020-09-22 9:57 PM dodge59 - 2020-09-22 6:30 PM Soooooo.....11-26 might explain why it has the flat antenna bases from 1958. No. It has tapered bases, as it should. Ply and Dodge went with the tapered bases after the 57 model year. Ron These are 1959 dodges on the green 59 dodge . I zoomed in on the pink cars antennas and they are a flat base. Edited by dodge59 2020-09-23 8:11 AM (Antenna_2med.jpg) Attachments ---------------- Antenna_2med.jpg (90KB - 170 downloads) | ||
dodge59 |
Elite Veteran Posts: 1018 Location: Milwaukee Wisconsin | 58coupe - 2020-09-22 9:12 PM Notice the heater hoses are not connected, maybe it needs a new heater core or valve. Probally a leaker ! | ||
ronbo97 |
Expert Posts: 4042 Location: Connecticut | dodge59 - 2020-09-23 8:02 AM These are 1959 dodges on the green 59 dodge . I zoomed in on the pink cars antennas and they are a flat base. You really can't tell from the photo. You would have to view the antennas from the rear of the car to see the taper. Ron | ||
jbloving |
Member Posts: 17 | Craigslist post had expired....here is new link: https://greensboro.craigslist.org/cto/d/greensboro-dodge-custom-d500... | ||
Expert 5K+ Posts: 9904 Location: Lower Mainland BC | . I am surprised that there is no D500 badge on the trunk, just the sides. Was that a 1959 D500 thing? | ||
Expert 5K+ Posts: 7400 Location: northern germany | 56D500boy - 2020-09-26 11:05 PM . I am surprised that there is no D500 badge on the trunk, just the sides. Was that a 1959 D500 thing? Yes, and if I owned one of these beauties, I couldn't move it fast enough to the trunk, also the ugly square gas tank door and the stupid straight pipe that runs thru the trunk would have to go. I would move the filler pipe to a taillight or the large chrome piece above. I love these cars but what were they thinking? | ||
dodge59 |
Elite Veteran Posts: 1018 Location: Milwaukee Wisconsin | 56D500boy - 2020-09-26 10:05 PM . I am surprised that there is no D500 badge on the trunk, just the sides. Was that a 1959 D500 thing? :) 1957-58 had one emblem on the trunk. | ||
dodge59 |
Elite Veteran Posts: 1018 Location: Milwaukee Wisconsin | jbloving - 2020-09-26 6:28 PM Craigslist post had expired....here is new link: https://greensboro.craigslist.org/cto/d/greensboro-dodge-custom-d500... I see that is has been taken off the internet. | ||
jbloving |
Member Posts: 17 | Sorry....the craigslist link was wrong. This should work: https://greensboro.craigslist.org/cto/d/greensboro-dodge-custom-d500... | ||
dodge59 |
Elite Veteran Posts: 1018 Location: Milwaukee Wisconsin | he must have re-posted it . | ||
lozrox58 |
Extreme Veteran Posts: 308 Location: Newcastle Australia | I love it. Pity the dollar is so poor at the moment. | ||
wallydodge |
Member Posts: 36 Location: Brooklyn, NY | Here’s the antenna base Attachments ---------------- 3B108F33-3056-4935-B8A5-033D4A2646DD.jpeg (73KB - 167 downloads) | ||
Lancer Mike |
Location: The Mile High City | From the image, it looks like the canted base (with what looks like a home made flat gasket). Very, very unlikely that any 1959 Dodge should have come from the factory with a flat base, as that was early 1957 only. Neat looking car! | ||
CaprockClassics |
Elite Veteran Posts: 628 Location: Lubbock, TX | Pitting/condition on those bases seems much worse than the rest of the chrome, maybe were added from a different car? | ||
dodge59 |
Elite Veteran Posts: 1018 Location: Milwaukee Wisconsin | I agree on the pitting of the antenna bases , but they are the 59 dodge style antennas not the flat bases style . Also that 4drht was restored back 2000. I talked to the gentleman selling the car . He also said all the chrome items of the back of the car were refurbished . | ||
wallydodge |
Member Posts: 36 Location: Brooklyn, NY | Yes the pitting is bad on the antenna bases. Tail light and rear bumper were re-plated 20 years ago. Rest of chrome has the slight amount of “dotting”. Very solid car. Slight rust bubbles on bottom of drivers door. But rockers and quarters are solid seat fabric not original but looks good. Couldn’t tell you how it runs and drives though. The seller for the lady who owns it had the gas tank off and line disconnected and it needed a battery. First I would do is change the wheels to spinners and white walls like it should have. Those knock offs are hideous and the back passenger side is missing the spokes. Edited by wallydodge 2020-10-08 4:20 PM | ||
