60 plymouth fury to disc brakes
dustympage
Posted 2020-10-12 7:38 PM (#604396)
Subject: 60 plymouth fury to disc brakes
New User
I have a 1960 Plymouth fury with drums. I was hoping i could get some info on a more modern car that i could use the spindles from. It seems like a question the internet does not have the answer to. I appreciate yalls help!
Posted 2020-10-13 12:37 AM (#604401 - in reply to #604396)
Subject: Re: 60 plymouth fury to disc brakes
5000
AAJ or Scarebird.
I went with scarebird.
Both kits now handle 14 inch stock rims. It so much simpler to go with those..
Search is your friend man Tons of posts on this.
Posted 2020-10-13 2:47 PM (#604427 - in reply to #604396)
Subject: RE: 60 plymouth fury to disc brakes
20001000500100100252525
Welcome to the board.
Spindle swaps entail fitment problems, the sources Mike listed fit the original spindles.
https://scarebird.com/index.php?route=product/product&path=64&produc...
Richbo
Posted 2021-04-01 5:55 AM (#610581 - in reply to #604396)
10010025
Cheap and easy disc brake conversion I created for my 61 Plymouth wagon when I got it 15 years ago. I used 66-72 C-body rotors and 72+ 1/2 ton dodge pickup calipers with home made 1/4 inch steel adapter plates bolted to the stock spindles. Cost less than $100 total.
Mopar1
Posted 2021-04-01 7:06 AM (#610583 - in reply to #610581)
2000100025
On my '60 Plym I used '77 NYer spindles.
Posted 2021-04-01 12:15 PM (#610592 - in reply to #604396)
5000200020005001002525
Yep, F/M/J body spindles & brakes work if you want to go that route, but it's much easier & better IMO just to use a kit with your original spindles. The only benefit you get with the spindle replacement is it is easier to remember what rotor and what caliper you have on the car, but that's not a big deal. Just write it down and save it somewhere in the unlikely event that Scarebird goes out of business.
madfins
Posted 2021-04-03 10:07 AM (#610642 - in reply to #604396)
At the same time you are going from drums to discs (assuming only the front wheels) are you going to be replacing the original
single reservoir master cylinder with a dual?
phish1270
Posted 2021-04-29 10:14 AM (#611525 - in reply to #604401)
mikes2nd - 2020-10-13 12:37 AM
AAJ or Scarebird.
I also went with Scarebird. Their brackets are very nice (a bit pricey) & they give you a list of all the parts to buy. It was very easy & well worth it. I just did my '61 Dart this past winter.
Posted 2021-04-29 12:44 PM (#611539 - in reply to #610592)
Gotta remember, factory disc parts are getting hard to find in some parts of the country (world) and you often have to beat the bushes to find them. The aftermarket stuff is a mouse click away and less work.
Stroller
Posted 2021-05-09 11:08 AM (#611850 - in reply to #604396)
1001001002525
Plymouth used the same upper n lower ball joints from like '57-'72. The lower ball joint n steering arm are the same from '62-'72. The upper ball joint is the same all the way from '57-89 in the Gran Fury. But yep the up to '72 are the Satalite, GTX, Road Runner flavors, hard to find just the spindles. I have been trying to get a set of spindles for less than $500.00 each just to check fitment on my '60 fury. The outer tie rod end is what makes me wonder. What makes this most likely a no go is because of the outer tie rod with that roll around bend in it. But still if the steering linkage would transfer from one the muscle cars maybe so. I simply do not know.
I do know of one kit pieced together basically that uses front calipers from a chevy cosica.
