Spring for inner door handle
1961plymouthfury
Posted 2020-10-30 9:11 AM (#605058)
Subject: Spring for inner door handle
200050010025
The drivers inner door handle will not go back by itself . It's got to go back by manually . My dad checked it and the spring is broken If any one here has 1 please let me know .
samstrader
Posted 2020-10-30 2:33 PM (#605073 - in reply to #605058)
Subject: Re: Spring for inner door handle
10010010010025
You can get all kinds of springs at Ace Hardware. If you can see the spring size on the other door, that will help you fine the correct spring. The spring does not have to be the exact match so Ace should work out real good for you.
1961plymouthfury
Posted 2020-11-05 10:51 AM (#605319 - in reply to #605058)
200050010025
thank You I will give them a try
