Torqueflite shifts hard into reverse. Bang!
fivespeedv8
Posted 2021-04-06 8:42 PM (#610757)
Subject: Torqueflite shifts hard into reverse. Bang!
I have a '59 dodge coronet D500 with a freshly rebuilt 383 and the original transmission that was rebuilt by the previous owner 25+ years  (and 20k miles) ago.
The car has been off the road for several years and I've gotten it back together, but the transmission shifts hard into reverse with a bang and will break the rear wheels free (chirp!)  even with my foot on the brake. The transmission was doing some other weird things until I adjusted the Kick down lever all the way forward to eliminate that is a possibility. Naturally I won't downshift now but that's the least of my worries.
I suspect the previous owner added some sort of a shift kit a part of the rebuild, but I don't know if that would be the culprit. Could this be a pressure or band adjustment issue? I've never monkeying with those sort of things on this transmission. The only thing I've done was drain and change the fluid, And based on the recommendation of the transmission rebuild or who inspected it, I used Dex/Merc with 1 quart of type F. I'm wondering if the added friction of that portion of type F is causing the issue.
Shep
Posted 2021-04-06 9:07 PM (#610759 - in reply to #610757)
Subject: Re: Torqueflite shifts hard into reverse. Bang!
20001000100100100252525
The reverse apply servo spring could be wrong or broken. Also the transmission line pressure could be too high. Shop manual has a pretty good diagnostic chart. Band adjustment is not your problem.
Posted 2021-04-07 1:29 AM (#610765 - in reply to #610757)
500050002000100025
You should not push the reverse button directly. Start the engine, push the D, and let the pump fill up the circuit and build up the line pressure. Then press the R. If there's no hard clonk then it's ok.
The R used the highest pressure in the transmission and if the R is pushed in on an empty circuit there will be a pressure shot that can destroy the transmission. Even worse if the engine is revved for to build up pressure.
