'61 Manual master cylinder Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
chefothefuture |
Member Posts: 49 Location: Chuckanut Mountain, Washington | Hi all- I have a problem with a manual master cylinder not letting fluid return fully so the brakes don't release. New return springs all the way around. Since there is no adjustment to the push rod, is there anything else that could be the problem? The cylinder was rebuilt but I'm not sure what to look for. Cheers, chef | ||
Expert 5K+ Posts: 7402 Location: northern germany | Maybe the residual valve, it is known to mutate to a one-way valve after 50-60+ years of use. It resides inside of your MC | ||
mstrug |
Expert 5K+ Posts: 6500 Location: Newark, Texas (Fort Worth) | Check the brake hoses and see if they are collapsing. Squeeze them and see if they are hard also. If they are old, maybe just buy the three. | ||
Shep |
Expert Posts: 3399 Location: Chestertown, NY ( near Lake George) | Loosen the mounting bolts on the master when the brakes are tight, if they release, your problem is in the master or insufficient free play for some reason. | ||
chefothefuture |
Member Posts: 49 Location: Chuckanut Mountain, Washington | 1960fury - 2021-07-12 7:48 AM Maybe the residual valve, it is known to mutate to a one-way valve after 50-60+ years of use. It resides inside of your MC :) Being that it's a rebuilt cylinder, I'd say it's possibly defective then. Thanks for the tip :-) | ||
chefothefuture |
Member Posts: 49 Location: Chuckanut Mountain, Washington | mstrug - 2021-07-12 7:52 PM Check the brake hoses and see if they are collapsing. Squeeze them and see if they are hard also. If they are old, maybe just buy the three. They're all new. | ||
chefothefuture |
Member Posts: 49 Location: Chuckanut Mountain, Washington | Shep - 2021-07-12 8:47 PM Loosen the mounting bolts on the master when the brakes are tight, if they release, your problem is in the master or insufficient free play for some reason. I can pull the pedal towards me slightly so there is plenty of free play. The piston does fully return as well. Edited by chefothefuture 2021-07-12 11:42 PM | ||
Expert 5K+ Posts: 7402 Location: northern germany | Follow Daves (Sheps) instructions. | ||
mstrug |
Expert 5K+ Posts: 6500 Location: Newark, Texas (Fort Worth) | chefothefuture - 2021-07-12 10:38 PM mstrug - 2021-07-12 7:52 PM Check the brake hoses and see if they are collapsing. Squeeze them and see if they are hard also. If they are old, maybe just buy the three. They're all new. You did not tell us that did you? | ||
chefothefuture |
Member Posts: 49 Location: Chuckanut Mountain, Washington | mstrug - 2021-07-13 1:56 PM chefothefuture - 2021-07-12 10:38 PM mstrug - 2021-07-12 7:52 PM Check the brake hoses and see if they are collapsing. Squeeze them and see if they are hard also. If they are old, maybe just buy the three. They're all new. You did not tell us that did you? Well now I did :-) | ||
