parking brake locks up in reverse...
Posted 2021-10-02 11:03 AM (#615537)
Subject: parking brake locks up in reverse...
5000
Okay these arent self adjusting?
My parking brake locks up when i push the car backward... i can kind of unlock it again for a few feet by rocking it a bit... forward is fine.
Anyone else run across this?  what did i screw up?
Shep
Posted 2021-10-02 2:52 PM (#615544 - in reply to #615537)
Subject: Re: parking brake locks up in reverse...
20001000100100100252525
Sounds like it is adjusted too tight or improperly assembled.
ronbo97
Posted 2021-10-02 8:02 PM (#615550 - in reply to #615537)
Subject: RE: parking brake locks up in reverse...
2000200025
mikes2nd - 2021-10-02 11:03 AM
No. GM had those, I believe. Not Chrysler.
Ron
Posted 2021-10-02 10:41 PM (#615552 - in reply to #615537)
5000
i backed the brakes off completely... and felt to see if it was somehow catching... but the pad weren't moving and the reverse locks up immediately when you turn the wheels backwards...
I'm thinking i have a serious trans issue.
Richbo
Posted 2021-10-02 10:58 PM (#615553 - in reply to #615537)
10010025
Are u sure it's not the rear brakes !?
Posted 2021-10-02 11:35 PM (#615554 - in reply to #615537)
5000
well i do have a rebuilt posi... no its not rear brakes.. i was able to move it freely in reverse with the driveshaft off. so its something forward.
I felt the car go in reverse when i shifted into it but it didnt want to move...
I guess i could yank the parking brake pads out? lol and try
22mafeja
Posted 2021-10-20 2:33 AM (#616052 - in reply to #615554)
5001002525
I have had that issue with two mopar fifties cars. It went away when I removed the parking brake drum and inspected and adjusted everything. I had new shoes in both cases
and probably they were too tightly adjusted from the beginning. I didn`t get sure of what was the cause but I got rid of the problem.
Posted 2021-10-20 8:23 PM (#616075 - in reply to #615537)
5000
I actually removed the whole drum... it locked up when i tried to spin it backwards... The pan is full of fine graphite, and its only been warmed up for 20 minutes..
its halfway yanked out...
Stroller
Posted 2021-10-29 3:41 PM (#616396 - in reply to #615537)
1001001002525
the cable on mine was catching the adjuster that goes between the shoes.
Posted 2021-10-29 4:38 PM (#616402 - in reply to #615537)
5000
nah i completely removed the drum, the actual shaft wont turn in reverse, i found a serious amount of crud in the oil pan (it was spotless and only broke the cam in for 20 minutes or so and the bottom of the pan has alot of black in it).
Stroller
Posted 2021-10-30 2:00 PM (#616433 - in reply to #615537)
1001001002525
That sucks.
