Location: So. Cal | Modified with a rack & pinion, super bee hood graft, custom front suspension and a 392 hemi. Makes me wonder how much of the frame was modified and how the steering is setup.
https://www.ebay.com/itm/175267472080
1956 Plymouth Savoy with 1957 392 Hemi 30 over Racer Brown Cam, Hyd balance complete rebuild. Hot Heads Tunnel Ram with 3 1970 Holley Carbs. Mallory unilite dist. Block Hugger headers with 2.5" exhausts. Flow Master mufflers and cut outs for electric motors. Rebuilt 727 trans with reverse manual valve body and Boss Hog Street Bandit converter. 8 3/4 rear differential out of 67 GTX, 4:10 gears. New rear springs, front helix suspension and power rack and pinion IDIDIT steering column. Aluminum radiator thermostatically controlled. Autometer gauges B&M shifter. Tire and wheels are not new but OK, 4 15x8 Mag. New windshield and door glass.
Front clip no rust, hood has bubble from 1969 SuperBee metal grafted in. Doors - no rust all done in epoxy primer. Rockers and quarter panels under rear windows and front floor pass & driver were cut out and replaced. The only rust is in the left floor of trunk (see pics). Front seats are out of 1968 Chevelle. Runs and drives - needs cosmetics. Tires should be replaced. All new wiring: gauges and lights work. Title in my name. Non-op in CA. All interior and exterior trim in trunk of car. No time to finish, too many projects and I am old. Car is sold as is/where is. Dan
(Modified 56 Savoy.jpg)
(Modified 56 Savoy Engine.jpg)
Attachments ---------------- Modified 56 Savoy.jpg (140KB - 54 downloads) Modified 56 Savoy Engine.jpg (123KB - 55 downloads)
So this?
https://hothemiheads.com/intake_manifolds/hot_heads_single_plane.htm...
Location: So. Cal | Bid up to $9100, reserve not met. Now for sale with a BIN of $10K.
This is a pretty stupid way to try and sell a car. He would have been much better to just let it bid up to where it goes with his minimum price listed.
https://www.ebay.com/itm/175280489425?ViewItem=&item=175280489425&vx...
Edited by Powerflite 2022-05-13 10:53 PM
Location: So. Cal | This one eventually sold at the BIN of $10K. |
