Carter AFB Carburetor help needed.
Posted 2022-06-06 8:30 AM (#621945)
Subject: Carter AFB Carburetor help needed.
My 2927S Carter AFB needs attention after 10 years of service on my 1960 Imperial. My mate rebuilt it with a Walker kit back then.
I need help with info on who can supply a good quality rebuild kit for this carb. Also looking for info on the carb circuits and tuning.
I have started some research, and realized this carb is more complex than I first thought. No surprise there I guess, this Imperial does that to me!
The car has an off idle flat spot now that makes it bad to drive, so I need to address this asap.
I have pulled the top off the carb for a look, and found the floats are not set right, first problem.
Am going to dig into it further tomorrow. Am thinking to take it off the engine tomorrow after work and dig into it further.
Any tips/hints greatly appreciated.
Steve.
KcImperial
Posted 2022-06-06 10:41 AM (#621952 - in reply to #621945)
Subject: RE: Carter AFB Carburetor help needed.
2000100100100100252525
I've used the Sorensen Carburetor Kit 96-113D on several of my 1958 Carters, should also fit your 1960
https://www.autozone.com/fuel-delivery/carburetor-kit/p/gp-sorensen-...
Posted 2022-06-06 10:57 AM (#621953 - in reply to #621945)
500020002000500100100100100
This might help you:
https://www.carburetion.com/CarbNumber.asp?Number=2927S
https://www.carburetion.com/products/productdetails.aspx?part=KT-503...
https://www.carburetion.com/products/productdetails.aspx?part=AF2083
