56 Plymouth parts needed
Muffin1
Posted 2022-06-06 10:20 AM (#621950)
Subject: 56 Plymouth parts needed
10010025
I need for a stick shift transmission the holder that goes over steering
column and attached to the bottom of the dash.
i need the the bottom cover plate that goes over the bottom of the
bell housing of a stick shift transmission .
and a complete steering column for stick shift transmission do not need the steering wheel
and the cross member that goes on the frame for a stick shift transmission
Thanks Alex Navy Veteran
419 356 4320
Posted 2022-06-06 2:30 PM (#621959 - in reply to #621950)
Subject: Re: 56 Plymouth parts needed
5000200020005001002525
I have all of those parts from a '56 Fury. I'll try to gather them up and take pictures for you.
Posted 2022-06-06 11:55 PM (#621976 - in reply to #621950)
I think I buried the Fury dash in the trunk of my car. I don't feel like digging it out right now, and not sure I would want to separate it from the dash. So I will probably pass on that one. But here are the other parts. The bellhousing cover came from the Dodge parts that I accumulated, but it should be the same. The other two parts are from my '56 Fury. The column was chrome plated at one point. Sorry that the pictures are taken in the dark. Kindof a crappy view, but hopefully good enough.
Edited by Powerflite 2022-06-06 11:57 PM
(56 Fury Manual Crossmember.jpg)
(56 Fury Steering Column.jpg)
(56 Plym Manual Bell Cover.jpg)
Attachments 56 Fury Manual Crossmember.jpg (193KB - 60 downloads)
Attachments 56 Fury Steering Column.jpg (176KB - 63 downloads)
Attachments 56 Plym Manual Bell Cover.jpg (143KB - 60 downloads)
Muffin1
Posted 2022-06-21 7:48 AM (#622272 - in reply to #621976)
10010025
Hi Nathan,
Sorry can not find a way to get you, i wand the parts
Please call 419 356 4320
Alex
Posted 2022-06-21 10:49 AM (#622273 - in reply to #622272)
500020002000500100100100100
Muffin1 - 2022-06-21 4:48 AM
Hi Nathan,
Alex
If you click on the red "Powerflite" beside each of Nathan's posts, it will open up information, including his email address.
