17 tooth speedometer pinion gear assembly for cast iron TF trans
jboymechanic
Posted 2022-09-14 10:13 AM (#624265)
Subject: 17 tooth speedometer pinion gear assembly for cast iron TF trans
2000100100
Looking for a good, usable speedometer drive pinion gear for my cast iron TorqueFlite in my '56 Imperial. The gear should be red with 17 teeth. PM me if you have one.
Posted 2022-09-14 1:44 PM (#624272 - in reply to #624265)
Subject: Re: 17 tooth speedometer pinion gear assembly for cast iron TF trans
500050001001002525
These are hard to get as there aren't very many junk transmissions around to pull them out of. If you can't find one, I recommend purchasing a speed adapter to get the value you need. You can get them from Ebay or get an exact value from speedometer shops directly, for more money. They will even calibrate your odometer or speedometer to give you exactly what you need.
https://www.ebay.com/itm/115321397462
jboymechanic
Posted 2022-09-28 4:12 PM (#624565 - in reply to #624265)
2000100100
Thanks Nathan, I'll try this out.
