upper A arm bump stops Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
Mopar1 |
Expert Posts: 3034 Location: N.W. Fla. | Need upper A Arm bump stops for '60 Plym. Catalogs only seem to go back to '65 or so. looks like they are the button shaped ones from what is left of them vs the real pointy ones. What are the recomendations? | ||
Expert 5K+ Posts: 9905 Location: Lower Mainland BC | Mopar1 - 2022-10-20 8:40 AM Need upper A Arm bump stops for '60 Plym. Catalogs only seem to go back to '65 or so. looks like they are the button shaped ones from what is left of them vs the real pointy ones. What are the recomendations? I believe that the OE part number was 1825 314. That shows up in a kit offered by Mopar Mall https://www.moparmall.com/1960-61-MoPar-A-Body-Front-Suspension-Kit-... Summit and Danchuk show similar bump stops https://www.summitracing.com/search/part-type/frame-bump-stops https://www.summitracing.com/parts/dck-861?seid=srese1&gclid=EAIaIQo... (1960PlymouthFrontSuspensionShowingSection2-08-48Bumper.jpg) (1960PlymouthFrontSuspensionShowingSection2-08-48Bumper_PN1825314.jpg) Attachments ---------------- 1960PlymouthFrontSuspensionShowingSection2-08-48Bumper.jpg (165KB - 95 downloads) 1960PlymouthFrontSuspensionShowingSection2-08-48Bumper_PN1825314.jpg (148KB - 98 downloads) | ||
Mopar1 |
Expert Posts: 3034 Location: N.W. Fla. | surprised it's showing a cone shaped one. Wonder what height it is. | ||
madfins |
Regular Posts: 78 | The Mopar Mall link above leads to a 20 piece set for the 'A' body cars - Valiants and Lancers The Fury, Belvedere and Savoy cars were 'C' body cars - The link below points to the 'C' body 32 piece kit (though the drop down does not list Plymouth as an option) - https://www.moparmall.com/1960-62-C-Body-Imper-Front-Suspension-Kit-... | ||
Mopar1 |
Expert Posts: 3034 Location: N.W. Fla. | madfins - 2022-10-20 5:57 PM At this point I don't think I need the big kit. Looks like, hopefully, the bump stops & Upper and lower A arm bushings only.The Mopar Mall link above leads to a 20 piece set for the 'A' body cars - Valiants and Lancers The Fury, Belvedere and Savoy cars were 'C' body cars - The link below points to the 'C' body 32 piece kit (though the drop down does not list Plymouth as an option) - https://www.moparmall.com/1960-62-C-Body-Imper-Front-Suspension-Kit-... | ||
ronbo97 |
Expert Posts: 4042 Location: Connecticut | Quirey Quality Design should have them. You can call them or check the number in the old Gary Goers catalog. Ron | ||
Mopar1 |
Expert Posts: 3034 Location: N.W. Fla. | I was surprised that the drawing showed a bullet bra/cone shaped piece. The one that's fairly intact on mine is a button style about 1 5/8" across and 1 1/8 high. | ||
Expert 5K+ Posts: 9905 Location: Lower Mainland BC | Mopar1 - 2022-10-20 9:27 PM I was surprised that the drawing showed a bullet bra/cone shaped piece. The one that's fairly intact on mine is a button style about 1 5/8" across and 1 1/8 high. Just a thought: Perhaps the diagram is correct and at sometime in the past your car's bump stops were replaced with non-OE stops? There must be somebody with a 59-61 who can confirm/deny the cone shape was OE (or not). | ||
Mopar1 |
Expert Posts: 3034 Location: N.W. Fla. | 56D500boy - 2022-10-21 2:26 AM That's what I was hoping! :-)There must be somebody with a 59-61 who can confirm/deny the cone shape was OE (or not). ) | ||
Expert 5K+ Posts: 7401 Location: northern germany | Cone is correct for 60, just like shown in the FSM. | ||
Mopar1 |
Expert Posts: 3034 Location: N.W. Fla. | 1960fury - 2022-10-21 9:14 AM dimensions?Cone is correct for 60, just like shown in the FSM. | ||
Expert 5K+ Posts: 7401 Location: northern germany | Mopar1 - 2022-10-21 8:05 PM 1960fury - 2022-10-21 9:14 AM dimensions?Cone is correct for 60, just like shown in the FSM. Have to look for the OE ones. Sill have them, somewhere. I replaced my with taller polys, since I wanted to limit my suspension travel, to reduce stress for the bushings, especially the sway bar bushings, when the car is jacked up. Unless your engine can lift the front end, so the tires lose contact during acceleration, I recommend using taller/tougher rebound bumpers. The strut rod twists the lca bushing during suspension travel, it's ok for the normal up and down during driving, but not when the wheels are hanging down. For that reason I modded the dront suspension, so the sway bar (not the OE one) is also the strut rod, with a special bushing. Edited by 1960fury 2022-10-22 9:55 AM | ||
springsweptwing |
Elite Veteran Posts: 1141 Location: Blackpool, United Kingdom. | VW fits perfectly https://www.ebay.com/itm/172785960642?fits=Make%3AVolkswagen&hash=it... Or threaded ones here, https://www.ebay.com/itm/164052722305?epid=93663664&hash=item26324de... | ||
Expert 5K+ Posts: 7401 Location: northern germany | Mopar1 - 2022-10-21 8:05 PM 1960fury - 2022-10-21 9:14 AM dimensions?Cone is correct for 60, just like shown in the FSM. 1.1/2" diameter, 1.5/16" height, 3/8 UNF thread. | ||
Mopar1 |
Expert Posts: 3034 Location: N.W. Fla. | Interestingly enough..with the wheels off the driver's side has a gap of just under an inch, the passenger side has zero gap. | ||
Mopar1 |
Expert Posts: 3034 Location: N.W. Fla. | Mopar1 - 2022-10-25 4:50 PM Interestingly enough, Back on the ground both sides have about 2" clearance. The 2" or higher obviously won't work, so I guess the 1 1/4 1 1/2 ones will be the ones.Interestingly enough..with the wheels off the driver's side has a gap of just under an inch, the passenger side has zero gap. | ||
