| For 1960 Chrysler and Desoto 361/383/413, were original factory valve covers attached using studs/nuts, or bolts? Please only reply if you are sure. Thanks. |
Location: Southern Sweden - Sturkö island | On my '60 Saratoga with 383, there are studs mounted. When I removed the valve covers for to change the valve cover gaskets, I notised that no one ever removed the valve covers. So, studs are likely original. |
Location: christchurch New Zealand | I have a low mileage 60 desoto adventurer ,383, and it has studs for the valve covers.
Thanks Geoff
Location: N.W. Fla. | Studs usually indicate the holes go into water or oil... |
Location: Ramona, CA | Studs. They sometimes come out if the nut is stuck on them and get replaced with bolts, but studs are correct. |
