57 325 cylinder head bolts torque Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
resq302 |
Veteran Posts: 111 | I looked in the factory service manual under the cylinder head Removal and installation section but no luck. What is the correct torque for the cylinder head bolts? While my motor is out, I want to just check them. Thanks, Brian | ||
Expert 5K+ Posts: 9670 Location: So. Cal | 85 Ft-lbs | ||
resq302 |
Veteran Posts: 111 | Thank you! | ||
Expert 5K+ Posts: 9904 Location: Lower Mainland BC | resq302 - 2023-03-19 1:32 PM I looked in the factory service manual under the cylinder head Removal and installation section but no luck. What is the correct torque for the cylinder head bolts? While my motor is out, I want to just check them. You must have missed page 515. (57DodgeBoltTorques.jpg) Attachments ---------------- 57DodgeBoltTorques.jpg (149KB - 59 downloads) | ||
resq302 |
Veteran Posts: 111 | I think it was section 5 on page 147 that had about cylinder head removal and installation. I don’t ever remember seeing an area just for torque specs like at the end of the chapter in my 69 factory service manual. | ||
Expert 5K+ Posts: 9904 Location: Lower Mainland BC | resq302 - 2023-03-20 3:24 AM I think it was section 5 on page 147 that had about cylinder head removal and installation. I don’t ever remember seeing an area just for torque specs like at the end of the chapter in my 69 factory service manual. I don't know why you were using a 69 FSM for a 57. (??) If you don't have the 57 Dodge FSM, you can download it here: https://mymopar.com/service-manuals/ Download, open, save, use (it is searchable with Ctrl F) | ||
Mopar1 |
Expert Posts: 3034 Location: N.W. Fla. | 56D500boy - 2023-03-20 8:57 AM He said "like my", he didn't say he was using it...I don't know why you were using a 69 FSM for a 57. :) | ||
local2Ed |
Extreme Veteran Posts: 580 | resq302 - 2023-03-20 6:24 AM I think it was section 5 on page 147 that had about cylinder head removal and installation. I don’t ever remember seeing an area just for torque specs like at the end of the chapter in my 69 factory service manual. Starting on page 500 there is all sorts of specifications. | ||
Expert 5K+ Posts: 9904 Location: Lower Mainland BC | local2Ed - 2023-03-20 10:13 AM Starting on page 500 there is all sorts of specifications. Which is where page 515 comes from (above). And there is this on page 134/530 in the pdf (133 in the FSM): (57Dodge325HeadBoltTighteningSequence.jpg) Attachments ---------------- 57Dodge325HeadBoltTighteningSequence.jpg (149KB - 68 downloads) | ||
resq302 |
Veteran Posts: 111 | Cool. Thanks. Yes, we have a 57 fsm for our 57 Dodge. We also have a 69 fsm for our two 69 gtx convertibles. | ||
