241 or 270 maincaps or shortblock
oldhemis
Posted 2023-12-09 6:15 PM (#633033)
Subject: 241 or 270 maincaps or shortblock
Looking for a 270 short block and/or a set of 241/270 maincaps. Thanks!
Posted 2023-12-31 2:21 PM (#633224 - in reply to #633033)
Subject: Re: 241 or 270 maincaps or shortblock
500020002000500100252525
I have a 241 shortblock for sale. Email me if you are interested.
NorCal Newport
Posted 2024-01-12 1:45 PM (#633371 - in reply to #633033)
oldhemis, where are you located? I have a 270 block with main caps. Here's the information on it:
- block machined magnafluxed, bored .060” 6 of the 8 cylinders sleeved. Work was completed back in January 2022, block has been stored indoors, oiled and wrapped. Cost of machine work was $1400.
Other items I have that for sale that fits this engine. All parts cleaned, degreased.
- Front sump oil pan, no holes or rust. $200
- water pump housing $150
- motor mount- $75
- oil pump- $40
- timing cover gear & chain - $40
- camshaft retainer & bolt - $25
- factory oil filter housing - $25
- timing tab (mounts under water pump housing) $25
I DO NOT HAVE ANY CAM's CRANK's, INTAKE's, HEADS.
$1000 for the block and main caps
$1400 if you want everything else I have listed.
NorCal Newport
Posted 2024-02-09 9:31 PM (#633714 - in reply to #633033)
Subject: RE: 241 or 270 maincaps or shortblock
Are you still looking for a 270 short block and main caps?
