56D500boy![]() |
Exner Expert 10K+ Posts: 10645 ![]() ![]() ![]() ![]() ![]() Location: Lower Mainland BC | . Just found an old Bring A Trailer auction for probably one of Joe Perry's 56 Dodges, this one an LA built D500. When got to the final of 200 photos, I nearly cried. The car probably had a body-off restoration and repaint but the painter failed to mask off the cowl tag, losing "valuable" information and provenance. This is criminal (in my humble opinion) ![]() Starting with my LA-built 56 Dodge D500's cowl tag with no extra paint and showing the characteristic original masking tape mark (that held the paper build sheet to the cowl) Then two of the BAT D500. I can't read very much from the tag. I could guess but....:( Edited by 56D500boy 2023-12-26 1:54 PM (DaveFsLABuiltCustomRoyalD500CowlTag_Annotated.jpg) (56DodgeLAbuiltD500Coronet_CowlTagWithWayTooMuchPaint_1.jpg) (56DodgeLAbuiltD500Coronet_CowlTagWithWayTooMuchPaint_Detail.jpg) Attachments ---------------- ![]() ![]() ![]() | ||
frwl![]() |
Expert Posts: 2166 ![]() ![]() ![]() ![]() | . SG = 1 M1 = ? M2 = 4 M8 = ? M9 = 4 (1.jpg) Attachments ---------------- ![]() | ||
ronbo97![]() |
Expert Posts: 4159 ![]() ![]() ![]() ![]() ![]() Location: Connecticut | Yeah. Hard to read, to say the least. They should have used paint stripper to remove the old paint before painting. Also, it looks like they used modern, one-way screws to attach the plate. Sheesh ! Ron | ||
Old Ray![]() |
Extreme Veteran Posts: 517 ![]() Location: Invermere B.C. Canada - Rocky Mountains | Yes, ... in a perfect world. Unfortunately this one is as far as you can get from that ... and getting worse by the day. But I do have a inside track on some Gaza land with a ocean view if your interested. Edited by Old Ray 2023-12-26 8:47 PM | ||
mikes2nd![]() |
Expert 5K+ Posts: 5154 ![]() ![]() ![]() ![]() | lol thats some thick paint. | ||
22mafeja![]() |
Elite Veteran Posts: 737 ![]() ![]() ![]() ![]() Location: Finland | I believe those screws are correct , at least on a 57 LA built Coronet... Edited by 22mafeja 2023-12-27 3:12 AM | ||
ronbo97![]() |
Expert Posts: 4159 ![]() ![]() ![]() ![]() ![]() Location: Connecticut | 22mafeja - 2023-12-27 12:11 AM I believe those screws are correct , at least on a 57 LA built Coronet... Can you post another photo of a data plate held on by these screws ? IMHO, this type of screw did not exist before the 1980s. Ron | ||
56D500boy![]() |
Exner Expert 10K+ Posts: 10645 ![]() ![]() ![]() ![]() ![]() Location: Lower Mainland BC | ronbo97 - 2023-12-26 11:49 AM Yeah. Hard to read, to say the least. They should have used paint stripper to remove the old paint before painting. Also, it looks like they used modern, one-way screws to attach the plate. Sheesh ! 22mafeja - 2023-12-26 9:11 PM I believe those screws are correct , at least on a 57 LA built Coronet... ronbo97 - 2023-12-27 7:55 AM Can you post another photo of a data plate held on by these screws ? IMHO, this type of screw did not exist before the 1980s. Ron Ron and Ralph: Look at the annotated image above of my LA-built (May 56) Dodge's cowl data tag. They used the one-way security screws on mine. So it was a 1956 LA factory thing, not some amateur restoration shop. And speaking of amateur, after seeing that over over over painted cowl data tag, I was surprised to see that the VIN tag had been masked off professionally. ![]() ![]() Edited by 56D500boy 2023-12-27 5:09 PM (56DodgeCoronetD500_VIN_small.jpg) Attachments ---------------- ![]() | ||
hemidenis![]() |
Expert Posts: 3905 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Location: Northen Virginia | My 61 Chrysler came with those screws too, holding the license plate light assy. | ||
NicksGarage![]() |
Expert Posts: 1234 ![]() ![]() ![]() ![]() Location: Ramona, CA | ronbo97 - 2023-12-27 7:55 AM 22mafeja - 2023-12-27 12:11 AM I believe those screws are correct , at least on a 57 LA built Coronet... Can you post another photo of a data plate held on by these screws ? IMHO, this type of screw did not exist before the 1980s. Ron My 1960 Chrysler 300F has these screws holding the license plate light on. Same with my '60 NY parts car. The trunk lock is right above the light. | ||
56D500boy![]() |
Exner Expert 10K+ Posts: 10645 ![]() ![]() ![]() ![]() ![]() Location: Lower Mainland BC | . My LA-plant 1956 Dodge cowl date plate with the "security" screws. Photo was from the first week I owned the car in Sept 2016. Edited by 56D500boy 2023-12-28 11:28 PM | ||
Lancer Mike![]() |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Location: The Centennial State | I think it was only the Los Angeles CA plant that used that security screw type? One of my '58 Dodges had them. Hamtramck built cars used the regular phillips head screws. I'm not sure about Windsor and Newark. | ||
