RAM CAR TRANSACTION
matador440
Posted 2024-03-06 2:46 PM (#634074)
Subject: RAM CAR TRANSACTION
500100252525
GENERAL QUESTION? 1960 AND 1961 RAM INDUCTION CARS
Does anyone know what 3 speed manual transmissions were used in these ram inducted cars
THANKS SMITTY
Posted 2024-03-06 5:30 PM (#634082 - in reply to #634074)
Subject: Re: RAM CAR TRANSACTION
50002000100100100100
In 1960 NOT available in Plymouth cars
58coupe
Posted 2024-03-07 11:10 AM (#634101 - in reply to #634074)
100050010010025
The big block equipped cars in 60 used the Borg Warner T-85, not sure if it was also used in 61.
Posted 2024-03-07 3:04 PM (#634108 - in reply to #634101)
58coupe - 2024-03-07 11:10 AM
So Dodge got them? Plymouth didn't
matador440
Posted 2024-03-08 11:38 AM (#634128 - in reply to #634108)
Subject: Re: RAM CAR TRANSMISSION---STICK SHIFT
500100252525
From what I understand -- The T-85 did not come out untill 1962 and were in B-body MAX WEDGE CARS. Also if T 85's were used in a 60-61 Ram Car.s they would have to have a emergency brake on the back of the transmission. Ive seen plenty of T-85 3 speed transmissions- non of them carry a brake on the back of the transmission.
Edited by matador440 2024-03-08 11:41 AM
StillOutThere
Posted 2024-03-08 2:22 PM (#634129 - in reply to #634074)
2000100010010025
I have always understood that the '61 300G cars with manual transmissions used the Plymouth heavy duty (taxi cab option?) manual three speed). Since a number of 375 HP 300Gs were built with the manual, and most survive, I take this result to mean that trans was "adequate" with 375 HP and whatever the torqe rating. However the TWO 400 HP 300Gs with manual trans had greater torque. Both those cars had their transmissions replaced VERY early.
Posted 2024-03-08 2:46 PM (#634130 - in reply to #634074)
The 400HP Versions got the french (pont a mouson?) 4 speed, not the domestic 3 speed.
Apollo 61
Posted 2024-03-08 11:31 PM (#634132 - in reply to #634130)
5001001002525
I thought that xram 60/61 used the A745 HD ????
Edited by Apollo 61 2024-03-08 11:32 PM
58coupe
Posted 2024-03-09 9:44 AM (#634136 - in reply to #634074)
100050010010025
I personally owned a 60 Plymouth with a 361 4bbl. that came from the factory with the BW T-85. Yes it had a parking brake on the back.I am pretty certain it was used in 59-60 in Dodge and Plymouth cars with the big block engines The A745 was used in the 61 and newer cars. The standard Chrysler 3 speed was a much weaker trans as I had one in my 57 Fury and broke several of them with the 318. That is why Chrysler switched to the T-85 for the BB engines. A version of this trans. was also used in the 62-63 max wedge cars minus the parking brake.
