57-61 LCA Polyurethane bushings
Posted 2024-05-07 10:15 PM (#635087)
Subject: 57-61 LCA Polyurethane bushings
5000200010010010010025
I'm rebuilding a pair of 59 Plymouth LCAs, I have the correct bushings, but I checked the measurements of the sleeves and these happen to be common sizes, even metric compatible.
35mm (1.1/4") inside outer sleeve and 27mm outside inner sleeve. I checked my stock and 59 Plymouth Poly rear spring front eye bushings slide nicely in.... Very tempting...
Of couse they need to be modded, but hard Poly is not too difficult to machine. For the time being, I will use the stock bushings, but I tought I give this hint for others. Part number is in the pictures.
I LOVE Poly bushings. I installed them in my 60 (all rear spings bushings and all sway bar bushings, front/rear) 30 years ago, still no play or noises!
(lca1.jpg)
(lca3.jpg)
(lca4.jpg)
Attachments lca1.jpg (137KB - 11 downloads)
Attachments lca3.jpg (150KB - 13 downloads)
Attachments lca4.jpg (108KB - 10 downloads)
Posted 2024-05-07 10:27 PM (#635088 - in reply to #635087)
Subject: Re: 57-61 LCA Polyurethane bushings
Because these are 2 piece bushings, the inner sleeve needs a little collar added to the front end. Maybe someone knows of a better bushing application to start with?
Posted 2024-05-08 7:57 AM (#635092 - in reply to #635087)
50001000500
https://teamenergysuspension.com/?s=3.2126G
Can't find a size chart.
Posted 2024-05-08 12:14 PM (#635101 - in reply to #635087)
Yes, that Chevy application fits 57-59 Plymouth rear spring front eye I found out years ago. Very little modification needed. Inner sleeve accepts a 9/16" bolt, not 1/2". Turns out it can be modded to be used for 57-61 LCAs too.
Posted 2024-05-08 12:19 PM (#635102 - in reply to #635087)
OT the shaft of the LCA is bent! The LCA is perfect... Never saw that before
