More parts are here! Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
safetymike77 |
Expert Posts: 4533 Location: Ripon, WI | Check these bad boys out... They arrived today! | ||
safetymike77 |
Expert Posts: 4533 Location: Ripon, WI | Try again! | ||
safetymike77 |
Expert Posts: 4533 Location: Ripon, WI | Ok... for now, we still have to do the 100K! Dave, I hope you fix it soon! (Imperial 131.bmp) (Imperial 131.jpg) (Imperial 132.jpg) Attachments ---------------- Imperial 131.bmp (98KB - 215 downloads) Imperial 131.jpg (44KB - 224 downloads) Imperial 132.jpg (48KB - 216 downloads) | ||
MOPAR-TO-YA |
Expert 5K+ Posts: 5139 Location: cornpatch county, Southwest IOA | Well Mikey--- thats sure going to give the green machine the WOW factor----but will it be ready for Des Moines ??? ..............................5%........... | ||
safetymike77 |
Expert Posts: 4533 Location: Ripon, WI | I say yes. Driveshaft is only a week out. Tranny is mounted, just have to hook up the cables. Found a 62 shifter assembly with the parking lever, so I am going to work on adapting that for my park... Should have the engine back at the end of this week. Everything else is all new and ready to be bolted in! | ||
Windsor59 |
Expert Posts: 2596 Location: Upplands Väsby, Sweden | Hello Mike! I will not stay behind you at the red light trafficlight, I will gave upp before we race. I think it see very good at a mopar engie/fins car. Let us see whem you put it on. | ||
safetymike77 |
Expert Posts: 4533 Location: Ripon, WI | Well, where these are going is looking better. Check this one out... Trans is down in, and ready to go! (Imperial 138.jpg) Attachments ---------------- Imperial 138.jpg (59KB - 227 downloads) | ||
safetymike77 |
Expert Posts: 4533 Location: Ripon, WI | Lookie here! Ok... after a minor snafu with the engine to trans mounting (make sure the center hub fits in the receptacle in the crankshaft before you put it all together! I pulled my torque off, ground off the lip that was around it, and it all went together then! Now on to my mounts. (car 019.jpg) (car 020.jpg) (car 021.jpg) (car 022.jpg) Attachments ---------------- car 019.jpg (63KB - 222 downloads) car 020.jpg (51KB - 220 downloads) car 021.jpg (58KB - 226 downloads) car 022.jpg (64KB - 228 downloads) | ||
safetymike77 |
Expert Posts: 4533 Location: Ripon, WI | Oh, and this is in too. :D (car.jpg) Attachments ---------------- car.jpg (53KB - 219 downloads) | ||
RoyalGate |
Expert Posts: 2011 Location: Ballwin, Missouri | Mike, Glad to hear you got the trans problem solved.. Where did you get the carbs reconditioned? I've got two AFB carbs that will need a workover/restored before long. Edited by RoyalGate 2006-04-10 8:52 PM | ||
safetymike77 |
Expert Posts: 4533 Location: Ripon, WI | I bought the carbs outright from Vintage Speed. They have a website. You should check them out. I don't know if they rebuild em though. That hot rod silver finish would look great on some AFBs though. | ||
safetymike77 |
Expert Posts: 4533 Location: Ripon, WI | Well, the mounts are done, lots of parts on... just waiting for the heads to get back from the engine guy! Next step is getting the new pulleys pressed on the power steering pump and the alternator, and I will be ready to get that stuff together... Kind of in a holding pattern now until I get the heads! (car 024.jpg) (car 025.jpg) (car 026.jpg) (car 028.jpg) (car 029.jpg) Attachments ---------------- car 024.jpg (64KB - 226 downloads) car 025.jpg (55KB - 227 downloads) car 026.jpg (61KB - 226 downloads) car 028.jpg (67KB - 238 downloads) car 029.jpg (75KB - 221 downloads) | ||
safetymike77 |
Expert Posts: 4533 Location: Ripon, WI | Should have more for you tomorrow! (car 031.jpg) (car 032.jpg) Attachments ---------------- car 031.jpg (56KB - 217 downloads) car 032.jpg (73KB - 221 downloads) | ||
Kenny J. |
Inactive by user's request Location: Las Vegas, Nevada | Looks great, Mike. K. | ||
safetymike77 |
Expert Posts: 4533 Location: Ripon, WI | Here is some more progress. I am slightly worried about the fit of the Intake manifold, but at this point I am going to leave it as is and try to fire it. If there are any issues, then well, I am out a set of intake gaskets, but if it did seal good, then I am out nothing! You will notice the tight hood spacing to the carbs. It does close, but man is that front carb close to the hood. It is far enough away I can see its reflection though. Boy, now I know why they use those T handles for the valve covers, them things are a bear to get bolts in! Just barely squeaked the passenger side one past the heater box. In fact, I think I scratched it getting it on! So what do you guys think so far? I should be able to get it really close this next weekend, as I don't have my daughter, which means saturday and sunday I can work hard and see where it gets me. (car 033.jpg) (car 035.jpg) (car 037.jpg) Attachments ---------------- car 033.jpg (85KB - 231 downloads) car 035.jpg (58KB - 229 downloads) car 037.jpg (82KB - 227 downloads) | ||
57burb |
Expert Posts: 3967 Location: DFW, TX | Looks awesome. Is that a B or RB, what cubic inch? Surprised you can get a BB intake that tall to fit in a FL car... what you gonna do about an air filter? | ||
safetymike77 |
Expert Posts: 4533 Location: Ripon, WI | I may have too, but I have some ways I might be able to get a little more clearance. The adaptors for the carbs from vintage speed could lose about a half inch of height if I had to. that may happen. The front one is the worst. The engine sits with a slight backward angle to it, so the back carb is lower than the front one. We will see how it all works out though. If I have to, I will run it that way though. Maybe fab some simple screens to go over the top.... that is a 77 400 by the way... | ||
57burb |
Expert Posts: 3967 Location: DFW, TX | Nice. I used to have the parts to make a 451 for my '66 Charger (440 crank in a 400 block, with mains turned down to fit). Never did it though. You might consider a T-bird hood scoop like Mike P did. I think this looks great. http://www.forwardlook.net/forums/forums/get-attachment.asp?action=... Or, send that intake down to the local machine shop and have them machine the carb mounting pad an inch or so lower, then re-tap the carb mounting holes. That intake looks like it could handle it no problem. Good luck man! I really like that BB in there! | ||
safetymike77 |
Expert Posts: 4533 Location: Ripon, WI | Well, I am going for the sleeper look with mine, hence the goal to keep it under the hood, or else I do think that looks nice. My overall goal though is a 59 with a heck of an engine underhood that looks like a 6 banger powered car from the outside. The only exterior mods are hollywood flipper hubcaps and the stainless drip rail molding I added, though I am planning on doing carpet and adding rear seat belts pretty quick. | ||
Mike P |
Extreme Veteran Posts: 585 Location: SE Arizona | "......Well, I am going for the sleeper look with mine, hence the goal to keep it under the hood, or else I do think that looks nice. My overall goal though is a 59 with a heck of an engine underhood that looks like a 6 banger powered car from the outside......." I hear you, That was my intent too, just couldn't get the hood to close. A couple of tips for what their worth...... You'll want to run as big an air cleaner(s) as possible on your carbs. The small round ones tend to act as chokes on anything over 325 CI engines. I can't tell from from the pictures if your running large or small base Rochester's, if they are large base units they should be OK with progressive linkage. If they are small base units they may work with synchronized linkage(all carbs opening at the same time), or you may want to consider changing the center over to a large base unit. If you don't have linkage, let me know and I can post a couple of examples of some I have built. Something that would really help the 440 is a set of 68-70 C Body Hi Performance exhaust manifolds, besides looking cool, they flow as well as headers till the higher RPM ranges. They will also fit well, but would require modifying your head pipes. If your running the stock 77 440 water pump housing a 69-70 Impala Big Block radiator is a fairly simple upgrade that only requires building a couple of spacers and redrilling the bolt holes in the core support. You will also have to re-rout your tranny cooler lines. Generally speaking a 3 row is more than adequate to cool the 440. Thought I'd pass it along for what it's worth. | ||
safetymike77 |
Expert Posts: 4533 Location: Ripon, WI | Bought an after market aluminum water pump housing that has the hose on the correct side. So that is solved... I am going to choose between the 77 manifolds from the 400 and the ones from the 413.. May mix and match, as I know I will have to change the head pipes anyway... the radiator is my 3 row that I had recored, so that should work... the rocheters have the vintage speed progressive linkage.. I will see how it all works... | ||
Ray Bell |
Expert Posts: 2478 Location: Dalveen, Queensland, Australia | I'd rip that half inch off the adaptors and as much as I could (is there almost an inch there?) from the manifold if I was you... Use Sikaflex if necessary. It's okay for manifolds. | ||
safetymike77 |
Expert Posts: 4533 Location: Ripon, WI | Huh? What is that? | ||
safetymike77 |
Expert Posts: 4533 Location: Ripon, WI | Problem solved. I must tell you, the guys at Offy are great! Knew I needed it for the weekend, and I had it today! I just ordered it Wednesday, and it had to go through one of their vendors!!!! (car 039.jpg) Attachments ---------------- car 039.jpg (98KB - 217 downloads) | ||
Ray Bell |
Expert Posts: 2478 Location: Dalveen, Queensland, Australia | Same it's not dual plane... Sikaflex is the stuff windscreens are glued in with... roof panels are glued on with it. One race team here had to polish out an inlet manifold to get it cleaned up, they couldn't do it without cutting it open. They stuck it back together with Sikaflex. | ||
Mike P |
Extreme Veteran Posts: 585 Location: SE Arizona | "....Same it's not dual plane..." (Shame?) Their really not too bad of a manifold, but the Offenhausers can be a bit touchier to dial in. Hopefully the guys who built the carbs already have them at least pretty close. Altitude/temp changes can make a big difference on jetting these as well as distributor advance curves. I suspect you will defiantly want to run synchronized linkage with the small base carbs on it or upgrade to a large base center carb to run progressive linkage. See what happens. I've have a bit of experience dialing these in, it can be a bit frustrating sometimes, but there's nothing like it when you kick it and everything's right. Don't worry about the old wives tales concerning KEEPING them in tune.... once their right they stay that way at (least with Rochester's). These are all my current tri-power motors. The Ch**y (also an Offenhauser) was run on a several different motors over the years, and had to be re-setup on each. The BB Ford (also set up with Rochester's) was run for years on my 61 Bird and that design was a lot less pickier to get right, it's currently in my 64 full-size. The Hemi set up is still a couple of months away from being fired in the 57 Plymouth, and I really interested to see how that one does. Like I said I've done this before, and if there's any help I can give you let me know. (engine pile.jpg) (engine pile.jpg) Attachments ---------------- engine pile.jpg (57KB - 254 downloads) engine pile.jpg (57KB - 215 downloads) | ||
safetymike77 |
Expert Posts: 4533 Location: Ripon, WI | Ok... getting closer... Things I am waiting on, ignition box install, lower radiator hose. Got to do some power steering stuff yet, and some fuel line... Coming together! (car 040.jpg) (car 041.jpg) (car 042.jpg) (car 043.jpg) (car 044.jpg) Attachments ---------------- car 040.jpg (63KB - 220 downloads) car 041.jpg (80KB - 241 downloads) car 042.jpg (94KB - 228 downloads) car 043.jpg (92KB - 218 downloads) car 044.jpg (90KB - 221 downloads) | ||
safetymike77 |
Expert Posts: 4533 Location: Ripon, WI | Oh.... for Ray... both of these intakes appear to be dual plane.... | ||
Ray Bell |
Expert Posts: 2478 Location: Dalveen, Queensland, Australia | Don't look like it from this side of the world... Dual plane feeds front and rear cylinders on one side of the engine along with the centre two from the other side from on plenum, and the others from the other plenum. Like the one you didn't use. I know, it's probably not as important as some other things, but it's just another thing in seeking perfection. | ||
safetymike77 |
Expert Posts: 4533 Location: Ripon, WI | the offy has a divider down the center., i believe... | ||
Ray Bell |
Expert Posts: 2478 Location: Dalveen, Queensland, Australia | That doesn't make it a 'dual plane'... The purpose of dual plane manifolds is to feed cylinders that fire in even sequence, to keep the flow through the carbies constant and better metered. So with that setup as described, it feeds four cylinders that are in sequence as every second firing from one side of the carbies, the other four are similarly in sequence for the alternate firings. Here's a description of what I'm saying from a site I just looked up: "Dual Plane: Dual plane manifolds have shown to be more throttle and torque responsive at low and mid range rpm levels than most (but not all) single plane manifold designs. Cross-H manifolds are typical examples of these manifolds. Each half of the (usually 4 barrel) carburetor is isolated from the other - and from the other half of the manifold- by the plenum divider. Manifold passages are arranged so successive cylinders in the firing order draw from one plane - then the other. In a 1-8-4-3-6-5-7-2 firing order, cylinders 1, 4, 6, 7 draw from one manifold plane and half of the carburettor. 8, 3, 5, 2 are supplied from the other plane and side of the carburettor. Because there is less air to "activate" during each inlet pulse, throttle response is crisper and mid range torque is improved." Here's an example from a '56 Poly... see how it's an under and over setup? (56polyairgapmanifold.jpg) Attachments ---------------- 56polyairgapmanifold.jpg (21KB - 210 downloads) | ||
safetymike77 |
Expert Posts: 4533 Location: Ripon, WI | Well, I have fired it! Confirmed I have oil pressure, and I am ready to finish it up... I could only run it for maybe 15 seconds at a crack because I have to adjust the idle, but wow! Sounds good through open manifolds..... (car 069.jpg) (car 070.jpg) Attachments ---------------- car 069.jpg (99KB - 238 downloads) car 070.jpg (90KB - 218 downloads) | ||
Ray Bell |
Expert Posts: 2478 Location: Dalveen, Queensland, Australia | About time you got some noise out of it! Shhhh... don't wake the neighbours... | ||
safetymike77 |
Expert Posts: 4533 Location: Ripon, WI | But that is the fun part! | ||
safetymike77 |
Expert Posts: 4533 Location: Ripon, WI | Boy this would be a good weekend to detail up the engine compartment... Too bad it is still at the exhaust shoP!!!!!!! Grrrrrrrr | ||
